Tinting Tru-Oil
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=16834
Author:  Terence Kennedy [ Sat Apr 12, 2008 4:49 pm ]
Post subject:  Tinting Tru-Oil
Greetings,
I recently did a neck with Tru-Oil over a Z-Poxy fill and it worked out great. I really love it. Now I'm doing one where I want a darker neck.
Can you actually tint the Tru-Oil itself to get a darker color or should you satin the wood directly.
Terry
Author:  JJ Donohue [ Sat Apr 12, 2008 4:54 pm ]
Post subject:  Re: Tinting Tru-Oil
Terry...I use Danish Oil on my necks. It comes in several shades ranging from reddish to brownish. While I haven't used the colors on necks, I have used the cherry for a furniture application. I can't say what, if any difference True Oil vs. Danish Oil is, but I have been very happy as well with DO as a neck finish on my last 3 guitars.
Author:  jhowell [ Sun Apr 13, 2008 10:06 am ]
Terry--
I've done a couple of Tru-Oil necks and I do like them. I've not tried to add tint to the Tru-Oil. My schedule is to seal with shellac after sanding to 320. Then I stain to get the color I'm looking for, ususally just using MinWax stains, sometimes mixed together to get the right color. Then its Tru-Oil and 0000 steel wool time -- around a dozen coats, sometimes more. I don't pore fill mahogany necks (the headstock is the exception). I like the hint of pores on the neck after using Tru-Oil -- just my preference and I have the luxury of only building to suit me.
Author:  peterm [ Sun Apr 13, 2008 1:00 pm ]
I would recommend you stain the neck first to the desired shade and the finish the same way you did before.
Author:  Laurent Brondel [ Sun Apr 13, 2008 7:42 pm ]
I think Tru-oil is tung oil based like a lot of varnishes, maybe I'm wrong. I've tinted some Rockhard varnish with cocobolo and/or bloodwood diluted in an an alcohol/acetone solution. Works great.
Author:  Terence Kennedy [ Mon Apr 14, 2008 7:09 am ]
Thanks for the tips guys, I'll let you know what I wind up doing and how it turns out.
Terry
Author:  RaymundH [ Mon Apr 14, 2008 8:11 am ]
My Tru-Oil process was very simple and effective:
Sand to 320
Stain ( wait 24-48 hours to ensure stain is fully cured and DRY)
Z-Poxy
Light shot 0000 steel wool
12 applications of Tru-Oil (1 a.m. 1 p.m.) with light sanding (0000 steel wool) in between coats.
This is what I have done for a couple of necks and it worked nicely for me.
